NEW Install/Trace a program and append traced data to an existing traced item. Learn more
NEW Uninstall Wizard: detailed removal log of each item
NEW Uninstall Wizard: export scan results to XML file
IMPROVED Run Uninstall Wizard if default uninstall program succeeded but freezed and user canceled waiting
IMPROVED Uninstall Wizard now supports delayed removal (after reboot) of folders of any depth
IMPROVED Improved readability of Install Tracker installation log which is now also Unicode (UTF8)
IMPROVED Startup manager: improvements and fixes
FIXED Uninstall Wizard: fixed memory leaks
FIXED Fixed problem that prevented some InstallShield msi-based executables to start with Install Tracker
FIXED Fixed removal of .xml files of traced programs
FIXED Fixed waiting while some NSIS-based uninstallers finish their job
FIXED Fixed duplicates in the traced XML
IMPROVED Numerious small improvements and fixes
IMPROVED Support of Total Commander x64 for jumping to an app's installation location
More information
Download now
Uninstall Tool 3.4
Re: Uninstall Tool 3.4
3.4.0 Build 5352
- Fixed algorithm of discovering apps icons
- French, Persian translations update
Download now
Download now
3.4.0 Build 5353
- Fixed rare crash when installing a program with Installation Tracker
- Hungarian, Chinese_Simplified translations update
Download now
Download now
3.4.0 Build 5354
- Fixed rare crash happened during mouse interaction with program list
Download now
Download now
