Uninstall Tool 3.0.1 Release
This release encapsulates all fixes through builds 5210 to 5216
* Fixed incorrect shell extension behavior on Windows Vista/7
* Fixed some rare crash when using Install Tracker
* Fixed displaying of apps with size > 4 GB
* Improved main window behavior in maximized state
* Ukrainian, Greek Turkish, Chinese, Dutch, Arabic languages update
Re: Uninstall Tool 3.0.1 Release
3.0.1 Build 5217:
* Install Tracker window is now above all other windows after installation (when running from context menu "Install and Trace")
* Fixed extremely infrequent crash fix in Windows x64 (when scanning Start menu shortcuts)
* Improved icon detection
Download now
3.0.1 Build 5218:
* Improved initial caching when Uninstall Tool setup is completed
* German translation update
Download now
3.0.1 Build 5219:
* Polish, Hungarian translations update
Download now
3.0.1 Build 5220:
* Fixed bug: when a user had custom groups inside StartMenu->Programs (like Games, Office), Uninstall Wizard accidentally removed them completely
* Fixed some rare case with incorrect folder icons display in Uninstall Wizard
Download now
Wonneproppen
Post by Wonneproppen »
Hmmmm strange....not available over update function. pure chance that i see into this topic
Maybe a bug from version 3.0.1 Build 5218 or 3.0.1 Build 5219?
Thx for update ;)
Wonneproppen
It's a small fix, too small to bother all users. We accumulate such fixes and Uninstall Tool will notify user of an update with the list of all changes.
3.0.1 Build 5221:
* Bug fix in Install Tracker: some programs (like QtCreator) were not traced though a user was using Install & Trace
Download now
3.0.1 Build 5225:
* Fixed crash when removing Microsoft Office 2007/2010 and some programs that act like groups in the list
* Fixed some potential crash when removing entry from the list with high system load and low memory
* Improved font display on Windows XP when 'Small icons' option is enabled
* New digital signature (please report if you get "Unknown Publisher" warning from Windows)
Download now
3.0.1 Build 5226 - no program changes
* Updated digital signature, should work fine now.
Download now
3.0.1 Build 5227
* Persian and Hebrew interface translation
Download now
3.0.1 Build 5228
* Fixed 'RemoveService.bat' (for portable version)
* Fixed some small and funny issue, thanks to liikuri
Download now
